Root Anyone else have trouble installing usb drivers?
RC21
I'm rooted and trying to install the usb drivers for the android SDK and keep getting the error "The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for 32-bit systems."
I've followed the instructions but just can't get by this error. Anyone help?
i really couldn't get it working on windows. I decided to just install ubuntu on my netbook so i can dualboot windows and linux and dealt with it that way.
Thanks Cabbie. I ended up just using adv wireless. Still looking to get irt installed on the computer though.
That's the same way I ended up getting around the USB issue. Guess those USB drivers and 64-bit Win 7 just don't get along well together...
