Ok I cleared the settings on my phone before I flashed meanbean. And now I can't get my wallet to work. It will not add my card. It says card add failed. Any help would be very appreciated
maybe try and wipe dalvik cache and cache and re-flash the rom. you will not loose data and hopefully that will work. or you can just start clean with a full wipe and a fresh install.
Find, in the build.prop, your device ID. It should be jewel. Change that to Galaxy Nexus and wipe cache and dalvik cache. Then reboot. That used to fix some problems before. It might fix yours?
