AlexzanderT
Alright, Inspire #1:
I bought my HTC Inspire (ATT obviously) back in the beginning of August. The day I took it out of the box I had problems. It would constantly say I had no signal but anyone near me with ATT had full signal. It also would not let me connect to the internet. I called ATT they sent me to a store to exchange the phone.
Inspire #2:
I had this inspire, almost problem free for a few weeks. Then suddenly it started freezing often. Most of the time after freezing it would restart itself. It would start up and do nothing and run a loop of restarting itself. In order to make this stop I would have to remove the battery (with the phone on as when I pushed the power button, no matter how long I held it down, it would only lock the phone not give me the power off or restart options). After putting the battery in and letting my phone turn on it would work decently for about an hour and then it would do the same thing again. I finally got fed up and called ATT again. They suggested running the phone in Safe mode and doing a factory reset. I did both and that still did not fix the problem. I called ATT again....Cue Inspire #3!
Inspire #3:
ATT sent me another refurbished Inspire. When I opened this one I had hopes that the nightmare with this phone would be over. I powered up the phone and did nothing to it. I didn't change any widgets, change the background, or install any apps for fear of making the phone do the same thing as my last phone (not like I had many apps or anything on that one). I turned the phone on at around 1pm. By 10pm it had restarted itself and gotten into that loop. I let it do this all night because I did not want to mess with it and when I woke up had to take out the battery. Just when I thought nothing else could go wrong I encountered another problem. Suddenly my phone displayed a warning that my 'SD card was removed unexpectedly' a few seconds later it would say 'preparing SD card'. About 15 seconds later it would say 'SD card is damaged'. It would run this on a loop constantly (for over 48 hours now). I finally unmounted my SD card (thanks to good timing) and have completely removed it from my phone so that no files are damaged.
I have now contacted ATT again and am hoping for them to send me an entirely different phone (which they will eventually). The HTC Inspire is a complete waste of money and is just junk. Apparently ATT does not believe in any sort of a lemon policy either.
Anyone else had this much trouble?
