I’m getting an extra 4 or 5 hours using an insanely customized Juice Defender profile. For starters I have JD scale my CPU based on use so it underclocks when the screen is turned off. I have also seen a vast improvement allowing JD to toggle wifi based on the location data the phone is collecting over the Mobil network so it knows when I am in a location I have used Wi-Fi before and will turn off mobile data and connect to the hotspot. After enabling this setting I would recommend looking for a hotspot every ware you go including stores, restaurants, work, fiends, girlfriends. Just look for wifi anytime you are at a location for more than 10 minutes and after a week or two JD will start seamlessly connecting and saving you battery power without you even being aware it is doing so. I also allow JD to turn off 3g/wifi when the screen is off and then turn one or the other on when the screen is turned back on depending on location. I have it set to turn 3g/wifi on every half hour and let my apps sync during work hours. Is set to change to 10 minutes at 5:30 when I am done work and then every 2 hours after 2am until the alarm goes off at 7 just so I don’t wake up to all my apps trying to get online. You can even set a separate schedule for weekends. Anyhow Juice Defender is an awesome app that can give you hours of extra battery life.
