Is it really that big of a problem? Does it indicate that the screen is going to come off eventually or something?
I just checked mine and my wife's Evo. I had to take our cases off because otherwise you couldn't see it. I have it a little bit under 3 out of the 4 buttons and she has it a little under the home button. However, the room has to be darkened to notice it.
I believe I noticed this a bit even before we got the case and she did too but thought nothing about it. Also, even with the case on, I see light leakage coming through the ports at the bottom. It's extremely faint and can only be noticed in the dark but I noticed it while trying to plug in the charger in the dark before going to bed. It was very faint but actually helped me a bit in terms of finding the slot to plug in the cord.
Anyway, if it was an indication that the glass would start coming apart at some point, then I would be worried. Also, if it was spewing light profusely then I could see exchanging it for that too. Otherwise, I don't really see it as a problem for us at the moment.
Upvote
0
