Then I suggest you read this. Astronaut Says Aliens Have LandedI read bad things about the batteries...
So what you're saying is I am imagining I have 25-30% more juice at the end of the day with the 1750 than I do with the stock battery? Ruff.......
computerpro3,
Might it be possible that BatteryBoss had a bad sample of the 1750 battery? I'm not claiming it is 1750 but I do know I'm getting significantly better battery time than OEM battery. On my Eris it was 20 - 30% more. I have not really been comparing battery time to OEM with Incredible.
I know it is not same technology but AA NiMH batteries can very by as much as 900 mAh (2,000 - 2,900). The batteries are obviously the same size.
I have voiced an opinion on this link before, and I will do so again.
BatteryBoss is an incompetent experimentalist who has more need for attention than for truth. His claims have a couple of problems:
-Not all batteries were new. And even if they were never used, he does not know how old they are. Lithium batteries decay from the start regardless of whether they are used. This is a huge factor.
-He asked his internet friends to send him batteries. Not only are these not new, they have been used. He does not know the conditions under which they were used (temperature, charge/discharge rate). A high discharge rate could cripple a battery. Same with an obnoxiously hight charge rate. He does not know the history, and yet compares them to new batteries with no correction or normalzation.
When it feels like this one man douchebag is constantly shadowing every thread about battery life, yes.
After discharging the stock battery, I managed to get 6 hours out of it.
After discharging the Seido battery, I am still running it down after unplugging it 22 hours ago.
This isn't based on some random assholes "test". This is based on cold hard facts taken from 3 battery apps keeping track of everything and my own observations.
Anyone who has an axe to grind against Seido is a tool and needs to get a life. No one gives a shit about your crusade against some 3rd party company.
Amen. Thank you for using common sense... not a lot of people have it.
you can get a true high quality 1500ma TP2 battery from ebay for $15 shipped.
Do you have a link to these amazing batteries? I've searched for 1500 ma TP2 batteries and have found nothing. Searching 1500 ma batteries gets camera batteries, and TP2 batteries gets...3 results that won't fit in a phone.
how much longer is that battery last 1500 vs the 1300 ?
get a calculator.. damm.. its 15% more.
Didn't realize that the TP2 battery fit. Threw it in there and now it's charging. Hopefully I didn't kill more than 200 mAh of it with my TP2.
I thought there was some test done that showed the extended slim battery actually performs worse than the stock battery? so you people who are getting these long days out of it, how was the stock battery? I was TRYING to kill my incredible last night and after 3 hours of abuse the battery just wouldn't die... yet on the first charge it lasted maybe an hour...
I bought the seidio 1750 mAh battery for my eris. Once I get my Inc I plan on using the seidio battery. The 1750 is better than the stock 1300, not earth shattering, but enough to get me through a full day with high usage. My stock 1300 couldn't get close to that. I unplug at 5 am. When I get home around 6-7 pm, I still have 50% left in the tank. With the stock 1300 I would be at 20% or lower. Was it worth the extra $$? For me it was.
The 2150 from verizon might be a better option. I read it adds another 1mm in thickness? Don't know for sure....
I am a battery scientist lol
This is the only evidence I need to know that my purchase of the 1750 Seido battery was worth every penny.
Take your extensive battery testing back to the lab where somebody might give a crap. I prefer real world results.
Well it's all relative because we don't know how you use your phone; whether you've been pushing it hard or using it lightly. All of this goes into how much battery life we get and whether we need a larger capacity battery or not.This is the only evidence I need to know that my purchase of the 1750 Seido battery was worth every penny.
Can you give us a basic run down of your day ? How many calls and how long, did you play any games, internet usage, ECT, ECT please
After fully discharging and recharging the Seido battery after receiving it, I have watched 3 hours of video, wifi has been on 95% of the time, made 10-12 phone calls, approximately 10 txts, browsed the internet a ton, installed well over 30 apps, bluetooth on for 2 hours connected to my Moto S9-HDs and I am still on this same charge.
My original question still stands - can you explain to me - or find anywhere from a reputable source, how Seido can fit 450ma more into the SAME physical size battery, over an already top quality OEM cell?
I have one on order since Friday, because my battery is absolutely appalling. What is your screen brightness setting? Automatic or Manual? If manual, what number? Thanks.
are you serious..
If you are than you are getting awesome life from that 1750..
thx
