I support these devs because they support their phones.Yes. Same when I tried. Seemed as if something was there, but just a black screen.
)The new AOKP milestone 6 is great. There are a few additional tweaks you may need to flash (kernel update, camera fix) that make it extremely fast and stable. PM or ask for details.
On the other hand, there's are a handful of CM9 ICS ROMs out there. This ROM has good reviews but I haven't flashed it just yet. (Happy w AOKP!)
A compatible kernel should be included in the ROM. Just make sure you are doing a full factory reset from within clockwork before flashing.does this rom require a separately flashed kernel to work? I cant get it to boot properly... and if so, where might the best kernel for cm9 be?
sweeds, can you please give more details on the additional tweaks/fixes that are recommended for AOKP 6? Also, what general order do you load everything (i.e. do you load anything BEFORE you load AOKP)? I'd like to try reloading it and get it as solid as can be. Thanks!The new AOKP milestone 6 is great. There are a few additional tweaks you may need to flash (kernel update, camera fix) that make it extremely fast and stable. PM or ask for details.
