Hello all. I have an HTC Inspire 4G which seems to have recently lost all APN data so I cannot connect to my mobile network. Does anyone know what might have happened, and how do I fix it? Thanx for your help!
From the homescreen if you do menu-settings-wireless & networks-mobile networks-access point names, do you see medianet and mms apns? And if you tap medianet do the fields say not set? Mine also say not set but I was having trouble accessing internet so you can try to reset defaults that worked for me. My medianet still says not set in the fields but it works. So while on the in the access point names tap menu and restore default.
Thanx for the advice. I tried both options - twice - before I got it to work with the tethering trick you referred to. I'm back up and running for the time being. I'll keep looking to see what happened to the original apn.
