kevin@teslacoilsw
HomeSmack allows you to change your default Home or default Long-search app. It's similar to Home Switcher or Home Manager, but uses a method of selecting the default that works well with Android 2.2.
HomeSmack also has some special Motoblur features (that need more testing, hence posting to the Droid X subforum)! On rooted phones it lets you change the double-tap app to any app on your phone (QuickDesk or Powerstrip!) and it lets you install a patched VoiceSearch APK that:
1) Sends the standard android SEARCH_LONG_PRESS intent letting you select any normal long-search app.
2) Still lets you select VoiceSearch as the long_search app or use it normally from Launcher
3) Patches the security flaw noted here (Droid 2 bug allows anyone to make calls at passcode screen [updated -- Droid X, too] | Android Central)
1.0
• Renamed package (So uninstall the old one or you'll have two)
• Posted to Market
beta3
• Allows you to chose "Nothing" for double-tap
• If VoiceSearch is not installed it will prompt you to install the hacked version (no need to install it to /system)
From the Market (Free/ad supported):
Market link
Also at:
[APP] HomeSmack - Change double-tap Home and Long-search - xda-developers
1.0
• Posted to Market
beta3
Market link
Also at:
