Apple headphones on Galaxy, problems with sound.
chris76 - do your headphones have the 'skip' button? I assume they're just the straight ipod headphones with no buttons?
I still don't get why this ain't working, and it's starting to piss me off. Considering selling my phone, as it's not much use to me if the handsfree ain't working as it should.
Its simple. Its because there is no standard way to wire the 4 pin jack. Samsung have wired the 4th pin one way and Apple a different way.
The only way to fix it is to rewire your apple headphones - Either by cutting the wire, finding what needs to be swapped and resoldering it, or chopping the jack off the end and soldering a new one on.
Its not really samsungs fault!
But who does it the default way and who doesnt? As long as I can find some other handsfree than samsungs bundled one I'm happy. If the Apple one is the only one that ain't working, it's ok. I ripped it apart anyway cause I got so pissed. I'll never buy an Apple product as long as I live.
Thats just it, there is no standard way for the 4th pin :(
It'll just have to be trial and error to figure it out. Or maybe you can google for pinouts. I'm sure all the samsung phones use the same pinouts, so even if u cant find the ones for the galaxy headset you can probably find one for another samsung handset
Ok, then I give up. I'll sell my Galaxy straight away :(
Going for the new Acer android, or waiting for the Sony Ericsson Rachael.
I'll check what kinda handsfree they ship with first this time. It can't possibly be as bad as the Galaxy one anyway. But thanks for all the replies folks, it's really appreciated :)
Apple pinout:
http://pinouts.ru/PortableDevices/iphone_headphone_pinout.shtml
1 Left audio
2 Right audio
3 Ground
4 Microphone
The button shorts mic to ground.
I just looked at this properly, and it makes no sense. Because the first 3 connections must be standard. That only leaves pin 4 for the mic. Its possible the button on the samsung shorts another pin, but the without the button pressed it should work!
I've just held the two headphone jacks side to side, and I can see that the samsung one has a reses. The apple one doesnt go all the way in and so doesnt connect the right pin to the right spot.
Hmm actually the resessed part doesnt go into the socket. This is really wierd, doesnt make too much sense.
Ok I got it. Mic and ground are transposed between the samsung/iphone headphones.
Ok htf do you skip to the next track on the music player? press once seems to be pause/play, and hold it down skipped a couple of times, but now just takes me back to the main artists/albumns etc screen
It's random, sometimes it changes album, sometimes song, and other times it doesn't do squat.
So basically the ground and mic parts are switched around on the samsung vs iphone headsets? Seeing as the iPhone handsfree works on the HTC Hero, I'm guessing it's samsung that once again has messed up things. Way to go.
be aware that the remote for samsung is bugged and after a few phone calls its got a delay on it
it can only be used to pause or skip track
hold for 1 second to start musc player
tap once to stop or start track
tap twice with a .25 of a second gap in between presses to skip track
this is consistent but i find if i have a phone call then you have to hold 2sec to start and hold 2 secs to stop and there is no way to skip track till you reboot
It's not bugged for me.
Playing mode kicks in on a press. two presses in succession for track change. single press when playing to stop.
For incoming call, press dial to pickup, then hangup to end call and music resumes automatically. Button presses work normally afterwards.
v. Galaxo I5
ahh see i use it in the car with headset to stay legal
I answer with remote button (hold down button to answer and hold down to disconnect).
getting phone out of pocket and answering with buttons is not a good thing when driving
Handsfree works fine for me. Perhaps a different set of headphones/switch? (UK phone, end of Sep. with v.I4 firmware)
Scenario 1)
- Music playing (single album, normal, not shuffle)
- Phone rings.
- Hit silver button on cord which stops music and answers phone.
- When call ends, do not mess with button. ( If the other person does not hang up, there could be a problem, but that's very rare. )
- Call ends on remote disconnect.
- Music automatically resumes.
- Buttons still work as normal.
Scenario 2)
Music, ring, button, chat...
At this point, if you hit that sliver button one or more times and attempt to end the call, you may end up sending signals to music player, such as 'set the player to party shuffle and go to next track'. Buttons work well after that, but at that point its too annoying, so you'll probably just pull over, change back to album, single and carry on.
But at least you stayed legal and the buttons work as expected. :-p
Anyone else?
Hmm I dont mind too much if a call messes it up, but when i'm listening to music on the train or tube I want the buttons to work!
If i transfer 5 music tracks to the sdcard, then play the first one, i can skip to the next using the onscreen buttons. If i hold the button down for a second then let go, it pauses. If i hold it down again it plays. If i hold it down for 2 seconds, it skips to the next track. Then it just stops working for skipping. When i press it to skip it just goes to the main albumn/song selection screen.
I'm amazed that samsung couldnt even get this right :P
Yeah i tried the slight gap too, but it only seems to work a few times (till it gets to the bottom of the play list) and then stops. Then no matter what you do it doesnt work again unless you kill the music app and start it again :(
I've been playing around with lots of stuff on the phone tho. Maybe i broke something :P I'll have to restore it at some point
I got the same problems connecting my universal fm transmitter 3.5mm Jack like others seems to work when put under a little pressure so looks like poor fitting ports! Dissapointing that Samsung should incorperate non universal connections in the audio dept after showing new ground breaking cooperation with what is to be the universal standard in the micro usb charging port!
