Welcome to AF Raindash!!
Make sure that in settings-->accounts & sync 'background data' and 'auto sync' are ticked. Otherwise your apps will not update
When you boot into bootloader does it show Marvel or MarvelC? Asked another way, does it use a SIM card (Marvel) or not (MarvelC)?It's not only the google account though, also twitter and facebook have the problem
I'm not sure what you mean with Marvel/MarvelC
I'm using a sim card, to go into the bootloader I need to unlock my phone first I guess,
probably should just root it as I'm annoyed by the limited space to install apps (or doesn't cm change a lot to that?)
I'll give you both a thanks so far as I'm rather new to rooting and you are both trying to help me![]()
