Apps to sd for LG motion 4G?
I like Link2sd personally. Works great and doesn't break widgetry. Is widgetry even a word? :)
You can't use the normal app to sd apps on this phone because the internal memory shows up in the sd card partition & the sd card shows as external_sd
means link2sd doesnt work bro =/
i saw your post in my thread also. I tried it and it did nothing. Very nicely put together app though ..can do a lot of other things
Yeah, I'm using Link2sd on the Motion from day one. The best thing about it is I can have it connected to PC and widgets and apps all still work, unlike apps2sd. :) I have 150 apps linked to my 32Gib sdcard even though the Motion has ample storage.
How are you getting apps from internal to externally on 32gb sd card? :confused: previous post said link2sd cant move apps.. I downloaded and tried to.no avail.. If so help :smokingsomb:
First, you must be rooted. Next you must create a second partition on your external sdcard. I made mine ext2 using gparted. If on Windows you can use minitool partition wizard. Open Link2sd and it'll ask you which format for your ext. I chose ext2 but some folks choose fat for compat. I went into Link2sd options and checked autolink apps to sdcard. Link2sd moves the apk, library files, and dex files to the sdcard and creates a shortcut to those files on the device. The device still thinks the app is located on internal, so in settings/apps it doesn't show on sdcard.
