A2SD+
Moves apps & Dalvik cahche to your SD card
Lots of free internal memory!
You will be required to format you SD card with 2 partitions as laid out below
Partitioning your SD Card ready for A2SD+
Backup all data on you SD card (this will be wiped)
The card should be formatted with your standard FAT32 partition 1st followed by an EXT2/3 partition (I would recommend 512mb, EXT4 is also supported but may shorten the life of you SD card)
Linux users use GParted or a similar software.
For everyone else I would recommend using Rom Manager
Once you have downloaded ROM manager from the market, open the app and click partition SD Card, Select your EXT size and set 0mb for swap
Restore your data to your SD and the job is done.
you need to read the thread that you got the rom from on the 1st page.
it really gets to me that people do stuff without even reading the authors posts telling them exactly what they need to do
Flash Rom (you may need to toggle signature verifacation)
I go into rom manager - partition sd card - ext size 512mb - swap size 0mb - partition sd car OK - then i get this:
clockworkmod recovery v2.5.0.7
finding update package...
opening update package...
verifying update package...
E:failed to seek in /cache/update.zip (invalid argument)
E:signature verification failed
Installation aborted
