I am having issue's with me archos tablet. I need to try and get my table back to the reset. The apps lib i took of because i have so many problems out of it. I dont know how to update or upgrade my ap so I dont know what todo. Can someone please help.
I've read your post several times and I think your asking for information on how to perform a factory reset...correct?
If so, from the main screen press your menu button > Settings > Repair and Formatting > Either choose "Reset Android" or "Full reinitialization" (whichever option you are looking for...read the description of each to decide which is best for you).
Edit...just realized that you have the "Home Tablet". I'm not sure if the menu structure is the same or not but I believe it is similar.
