I am surprised that no one has used Aroma Installer in their ROM installation. It gives more choice to the installer so you do not have to make compromises on what features or apps to include in a rom, the installer themselves can pick for themselves.
Check it out:
[MOD][2.00] AROMA Installer :: 120425-020 :: Open Source [REOPEN-SOON] - xda-developers
As long as cwm or rzr aren't really barebones recoveries then this should work as long as it is put together right. This is used on all kinds of roms and mods because it turns multiple files and options into a simple all-in-one with a really interactive installation. This would also make for a pretty simple and beneficial debloater script. I hope you get to benefit from this awesome recovery add on :smokingsomb:
So any devs here up for the challenge?![Stick Out Tongue :p :p](/styles/smilies/google/stickouttongue.png)
Check it out:
Benefits For UsersAROMA Installer gives users the possibility to choose which mods and applications they want to Install on to their device. Sometimes we want the clean install, without bloatware; and sometimes we want the full set of applications on our device. With AROMA Installer, you are your phone's master!Benefits For Chefs/DevelopersAROMA Installer gives chefs many benefits:
You don't ever again have to hear someone ask to remove or include something they like into your ROM, just for you to yell "Hey, that is only your opinion! Only you and some other people like it; most people don't! Go remove the apps on your own with WINRAR, you ^$#&*&#$", remember they are still a customer, and with AROMA Installer, this problem can be solved.
If you are good at customizing the AROMA Installer it was possible to make your ROM compatible with many devices using just one ROM File. You save your time, bandwith and hosting maintanance.
With the great user interface in your ROM installation, users will be very happy with it.
With AROMA Installer, You Are The Greatest ROM Developer
