Root Articsteem (zvd)
Each theme and Rom thread has instructions. The instructions are all the same. No need to make another thread asking the same question that has the same answer.
Everything you need to know is in the guide or the search function. Let's knock the dust off of it and utilize when it's needed. ;)
Makes it easier on you because you get your answer right away.
well todays topic is READING.....:stupido2::pcguru::bath:
