jasondumoulin
does anyone know if the tapout has a differant model #
same phone diff look.does anyone know if the tapout has a differant model #
just that it has 2.2 n not 2.1 loloh ok I was wondering because I was looking for kernal-rom. on huawei web sight but only the original kernal is there. Is the tapout much better then the original? I have original flashed with icarus.
Actually, the kernal us different.
hi first time i went to metro and thay said we get update cobble weeks
I figured that with a newer os on it lolActually, the kernal us different.
We're having a lot of trouble with this. The rom from the TapouT does work on the regular Ascend but, they have only now got data working on it. You can get phone calls, sms and now data. They've still got to find a way to fix the wifi, and mms. -.- It's quite complicated for being the same phone.
EDIT: It's got data and MMS working now. Just got Wifi left on the list of not working things.
Pip - Thank You for trying so hard for us.
Anduiril - Thank you for providing this.
Does this mean once wifi works that it will be good to go??
