Root ASOP Rom (Destoyer v2) + Kernel (Snap Turbo)= Fun & Fast!
3VOcrack
Rom: DESTROYER V2 aka THE SEQUEL
[ROM]DESTROYER.V2 a.k.a THE SEQUEL... - xda-developers
plus
Kernel: SNAP TURBO
Download HTCEvo4G/kernels/SnapTurbo at DownloadAndroidROM.com
Guys this is a sweet ASOP Rom. Its been sitting down under ASOP downloads and I never thought to try it until last night. I spent all day customizing it with like 20 different themes. Fun Fun Fun.
I then got it how I liked then thought about the ol Snap Turbo kernel. Can this work? I applied the flash and BOOM! Im getting 2100+ Quadrant scores out the box.
This is a fast and fun set up. If you like Cyanogen, which are okay but crap like USB and 4g doesnt work, then you will love this. I am going to test Kings ASOP [KingsROM][ACS] NEW KingsROM Ultra BeatDown GB-R4 [GBKUB]-5/5/11] " BRUTAL "and [ROM][AOSP][2.3.5] SalvageMod v1.4 (4G Working).
Any feedback welcome!
I might try that. I love AOSP. And isn't destroyer the one that always had epic first posts?
yep magnus, the rom's dev, is nutty with his op's. the rom is great but there are issues with some of the menus be all black so it makes doing certain things hard. it is based off of cm7.
Anyone have a fix for 4G on this ROM???
Says it should work but my 4G just continues to search for signal.
it should. it is based off of cm7 which has 4g working. check to make sure that you have your keys still. try wiping dalvik cache and cache?
My Wimax (4g) isnt finding the 4g network. I just updated my radios and still no go.
