Root [AT&T] Flixster
MrClean
In case anyone is new to the Galaxy Note. If you are rooted and try to use Flixster, it will tell you that 'streaming for your device is not supported yet'. And the 'download' option is not available either.
Launch SuperSU, under 'Settings', uncheck 'Enable Superuser'. With the GN2, you had to reboot, I tested with the GN3 and a reboot is not required. I did long press the home button and 'close all' and then cleared the RAM with the 'Clear memory'. Launched Flixster and I had the ability to stream or download my movies. Don't forget to enable Superuser when you're done. :D
Happy watching!
So the only issue is when you stream on that app... Checking movie times is working fine?
I only stream on Netflix and YouTube
