Root Attain Deodexed Rom
mobileplay
Deodexed Rom, removed bloat, changed battery icon, uses gestures, swipe up on home screen for app drawer, swipe down to hide or show home screen menu bar. App drawer scrolls vertical instead of horizontal, transparent notification bar. Took me a couple days to finish. Please let me know if you like.
Please let me know if u have any problems and I will try to fix them asap.
https://www.4shared.com/archive/4SBXRBrK/DeodexedAll.html
https://www.4shared.com/archive/xnZKdIFj/GASMOD.html
CAN GO BACK TO STOCK BY DOING FACTORY RESET, WAIT ABOUT 5 MINUTES FOR FOTA UPATE THEN FLASHING ORIGINAL PREROOTED.TAR, ONLY TAKES ABOUT 15 MINUTES.
Thanks again shabby for helping me pull .rfs from phone after modding, and to tokenpoke for answering questions about deodexing. And to everyone else, without the links and info from this forum I would never have figued this out.
Now that its deodexed ill pull the apps, theme them up and send them to u. Ill be flashing as soon as this chick gets out my bed. Lol.
Not all apps would deodex, but most did, if u have any that are deodexed that I didnt get send them to me and I will add them to the rom.
well im running it now, no problems so far. i got family counseling to go to so ill work on the themes when i get back
Think I figured out why some of the apps wouldnt deodex, will upload another tar shortly all apps should be deodexed.
Cool, u should update the op with the new link and add instructions for the tar since a lot of ppl will be new to this
Got the system apps themed, working on the battery, signal icons and so forth. Ics theme by the way. Could be call GAS mod, (galaxy attain sandwich) lol
Sent from my SCH-R920 using Tapatalk 2
I may try to get another dev from the admire for some smali hacking, maybe get an aosp lock screen or something
Just checking to see if there's been any progress on this... awfully quiet round these parts.. lol. Anyway, thanks.
Its pretty much my fault its been quiet. I was supposed to get this themed rom to him.a while ago to make a tar ball of it. I've been a tad busy and the power was out in my neighborhood for a few days. Definitely this week though. I may have a lil trick up my sleeve for the launcher choice.
Just threw this on my daughter's phone last night. Looks nice. Would look freaking AWESOME with a little ICS flavor thrown in though. Keep up the good work gentlemen. And thanks!:D
Its a bug with the theme. When it's charging the battery only shows a small portion of red and tgr lightning bolt. It still charges correctly, just doesn't show the proper stats. Ill upload a pic
Edit: my signal sucks in this area. Lol.
Try flashing a rom with odin. I have had that happen a few times and for me I just flash a rom onto it as long as oden sees the connection which it should
