bigblackken
when someone sms me a number or address, android seems to make life difficult for me more often than not.
First, it won't auto dial or auto map correctly more often than not. . Then when you want to copy and paste it manually into the maps app, its impossible using stock apps and/or google voice.
for example 5551112222, (seven digit number is ok) but someone sending me (555)111-2222 won't work.
Its MADDENING for me. Are there apps out there that can do this better than stock or something i am over looking?
i tried it on the new EVO 4g lte and it does the same crap.
