hamsterhonda
well guys i am rooted and running xtrsense, running fully on cricket, thanks to pkopalek, he is the man!!, now im trying to flash different roms, and they go through perfect, but i need the autostartroot program from market in order to flash the cricket web and mms fix since its on my old rom and setup its not there after new rom,,, but i have no access to wifi, so anytime i flash a new rom, i need to flash the cricket fix, is there anyway to put autostart on the sd, so that i have access to it after i flash the new roms? that way when i flash the new roms, i can just pull up autostart, and continue, thanks again guys for the help!!!
[he helped me root way back when]
)... How do you install Astro if you don't have access to the Market? Can you get wi-fi (at a public hot spot) even briefly?
do. This is exactly what you do to switch from ROM to ROM that you've tried-out.
