stayboogy
Android Expert
i put this here because i think some have missed it in the merit sub-forums
relocate dalvik-cache to /dev partition
new script, simplified by me
**no support for link2sd / apps2sd in this release**
requirements:
a) rooted phone
b) cwm recovery
c) file explorer with root privileges
d) init.d scripting enabled http://androidforums.com/merit-all-...ripting-function-your-device.html#post5104672
requirements:
a) rooted phone
b) cwm recovery
1) download script above
2) copy script to your "system/etc/init.d/" directory
3) set permissions to 777
4) reboot to cwm recovery
5) select "advanced"
6) select "wipe dalvik-cache"
7) select "yes"
8) when finished, reboot phone--will take a couple of minutes to boot, this is normal
9) verify that dalvik-cache was moved to /dev
[NOTE: /data/dalvik-cache will still exist, but /dev/dalvik-cache is bound to it, and it's not actually taking up any space]
**if not moved, check the "scriptlog.txt" in "/data/local/tmp/" for errors**
you should now have dalvik-cache in /dev--will survive subsequent reboots without wiping from cwm
**to move dalvik-cache back to original location, delete "dalvik2devfinal2" from "/system/etc/init.d/" and reboot phone**
HIT THE THANKS BUTTON
before:
after:
SPECIAL THANKS
**thanks to DeeJayAhmed @ XDA for his base script http://forum.xda-developers.com/showthread.php?t=1638962**
*thanks to Motorhead1991 and valueforvalue for the inspiration*
