Root background image help on miui
Status
Not open for further replies.
the image isnt what the DX wants as far as size goes. Have you unchecked the box for scrolling wallpaper to see if that does anything?
when you look at the image zombie imagine that it fits entirely, the side edges didnt fit completely, but length wise it was complete
For the DX the wallpaper should be 960x854. yours is 320x480. With a small pic you need to expand the orange box around the image but then it gets grainy from my experience.
yes i know the image res for it, probem is though it doesnt expand the orange box up, its obviously in a square, and i need it more rectangular, i need height, not width, thats what im getting at, when its set properly, it looks perfect, moment i will upload the image of it on omfgb and post it
What its supposed to look like
What it looks like now
What trying to size the image does
I see what you mean now. Im at a bit of a loss to a solution. I dont use a wallpaper at all. My background is pure black.
yeah now you see my predicament, its confusing and i hope i can get it to work :p maybe someone else knows the answer to this.
hopefully
Ummm..... to get this to fit correctly, its gonna take me a little while to screw around with, but I'm pretty sure I can get it fixed for ya. If I had Photoshop CS5, it'd be no problem with the new content aware scale feature they added, but I've got CS4. Let me see what I can do with it tonight.
i dunno, i know in omfgb i rotated the image several times, and then it took the image completely, which is bizarre, but it works so im happy :)
Status
