Help Backing up Dinc's SD card?
Smudgie
I use Docs To Go which saves all files to my SD card. I also have several photos on my Dinc which are saved to the SD card. I need to back up the SD card. I am thinking maybe to my Dropbox account or something. Either way I need to get them to my PC for backup. I know that I can plug my Dinc into my PC's USB port and do a backup of the SD card that way and then transfer that folder to my Dropbox. However, is there an easier/more efficient way to accomplish this? Thanks
If you have dropbox on your pc and phone, just copy the desired folders/files to dropbox using the app on the phone. Then you can access them from the pc also since they're both synced to the same server. If you have a lot of files to transfer, it might be faster to connect to the pc via usb. Either way will work.
