The Samsung Kies program will back up everything on your phone.
So when I get it back, I restore and it'll be exactly like before my phone was wiped out? Home screens, icons, apps, folders, everything?
My phone is rooted, is that what you are talking about, or do I need to check the settings in Kies?
Thanks![]()
no it wont backup ure settings and widget and home screens the only way to get all that is nandroid backup.
In settings there is a factory data reset. Would that unroot my phone? I'm sorry it's a stupid question.
No mate, you need to find an unroot guide.
Also, recieving an update will unroot it.
Do you have to use the guarantee?
Won't simply copying the complete contents of your phone to your PC and then copying them back to the new phone do the trick? Pardon my ignorance, but I have never done this which is why I'm asking.
I can unroot it but what do you mean by reset the counter?
