Root Bamf 2.0 Build 5
tinosa
I just flashed to GB Bamf 2.0-5 last night and I'm having several minor issues that I was wondering if people could help me on...
First of all I'm on the standard Bamf kernel if that matters at all.
Problems:
1. I can't move any apps to my sd card. It keeps giving me an error telling me its out of memory when there is 25 GB free on the card.
2. The Voicemail icon won't go away.
3. Pandora won't play. It did play and stop but I uninstalled it and reinstalled it and now it won't play at all.
Thanks for your help!! I need it!
Did you do a full wipe before flashing? Did you use ROM Manager to wipe/flash?
Sorry I forgot to mention that, I did a full wipe of memory/cache/Delvik/battery stats. I did only do it once though..thinking about wiping everything again and re-flashing. What do you think?
by memory do you mean data/factory reset?
i would check the md5 of your download and compare it to whats listed in the bamf thread. if it matches your download is good. if not,download it again.
boot back into clockwork recovery and wipe data,wipe cache,and wipe dalvik cache and reflash.
see if that helps. also be aware that there is a radio change required. did you flash the new radio?
Problems:
You might want to flash another rom. Sorry, but #2 and #3 were deal breakers for me on GB. The voice mail icon does not go away until you reboot. VM notifications do not come in unless you reboot too.
Pandora did not work no matter which version I used. I flashed another rom and it works as it did previously. Remember, GB is a hack, albeit not a good one. It's pretty and almost everything works, but it comes from a leak that was never released.
yea, its buggy, im pretty happy with bamf but i need and use pandora daily, its almost a deal breaker but im getting by.
Mine works but it will pause after each song, i just have to help it out a little to get it playing again. pita but will hold off till bamf releases a newer version that is compatible with pandora. they are close to next version.
im a pandora fan also... been awhile since ive been on bamf,but i thot i remembered it workin for me... just took a long time to start playin. once it got goin it was ok,unless you pushed skip,and then it took a long time again to find a song.
is that the prollems youre having? or are your issues different?
It's all of the above. When I had Pandora loaded on my TB with GB it didn't even work on my Dinc that has CM7 on it. As soon as I loaded CM7 on my TB Pandora started working flawlessly just as it did before. (haven't checked the DI yet, no need at this point) It was slow to start, slow to skip songs, slow transition between songs and nearly unusable. I even fired off an email to them since I'm a paid subscriber. Reply back was rooted phones can't be supported, although they were very nice about it.
So until GB gets formally released I believe it will continue to be a problem.
I'm on bamf pr4 and Pandora is working quite well for me. There is only a brief pause between songs.
