Thus far rc4 rocks. Im experiencing no lag whatsoever. I'm using speedtweak with the batt saver script.
No setcpu.
I recall some people getting lag from using setcpu even after allowing for its use in terminal emulator. May be worth a shot.
where did you find speed tweek?
It is a script built into the kernel to be used for overclocking. Just open up the terminal, type su, enter, then speedtweak.sh, enter, and it will take you to the options for overclocking and governors.
how do i install the weather wall fix that was posted? Just drop it into root on sd card? Or do i actually have to flash it thru clockwork.
Questions guys.
coming from RC3, do I have to wipe all before going to RC4?
i know they said its recommended to do a full wipe, but I am not sure if that applies to the BAMF roms.
i, like most, always wipe data regardless of rom choice.
i wiped coming from rc3 to rc4. i have read where some didnt. but i figure its better to be safe than sorry. not wiping could cause you some little problems that you may falsely account to the rom itself.
Digdug, do u prefer Setcpu, the speedtweak.sh script, or use the no frills overclock built into the toolbox? I usually adjust using the toolbox myself but wondered which was better for u, or anybody else for that matter.
Go into the tool kit and select terminal emulator. Type
Su then press enter
Speedtweak.sh press enter
As funny as it seems, i typed it in wrong twice cause I am blind as a bat and the typeface is tiny in terminal emulator.
