Yep, that's what they are. Kind of cool but it felt like I had a different phone. It was just so slow. The download is 358 MB whereas Liquid is 68!! I might have played with it for a bit but VM is not working still and I need that. Figured while I was at it I got a GPS lock, backed it up and then restored my aosp. But it's worth it if you have a few minutes just to check it out.Those expandable widgets look pretty cool (at least I am assuming that's what they are).
Everyone knows I am a huge BAMF fan, I have been running their latest (BAMFForever) and the ROM is absolutely perfect. They have been talking about a Sense 3.5 port, and well...Here it is folks. The first Sense 3.5 ROM on the TB, and I am sure as bugs get fixed new releases will be coming out as well.
For those of you that actually DO like Sense out there
Multiupload.com - upload your files to multiple file hosting sites!
MD5: 1ba2cc579bdc6d5b0169cba224aef2a5
i ran it for a little bit last night. I dont really see the point of the expandable widgets...they dont really give any information. the messages just shows me the latest text message, but doesn't give a name, just the number
new e-mails dont show up
no "pop up" messages for gmail
they really need to make them more useful. its a cool idea, but they dont really add to the experience. I do like the rotation animation, and i like the widget/skin/lockscreen picker. volume (tap to mute, 1/2 vol/full volume) is cool
dialer/contacts is cool
phone seemed to run a little hot compared to bamf forever
i do like the newer widgets
overall, it was pretty solid for me, some stuff seemed a little mis-sized (lock screen icons) but it could be a DD ROM for me.
i had to move my battery monitor to a different one.
The bliss has a different screen resolution, IIRC, so that it probably why things are mis-sized--the dev has to go in and fix every little thing to make it work.
and restored a forever backup. I actually realize that i like the larger icons on the home screen and lock screen.....
bj,may wanna add something about it being sense 3.5 in the title... it may give the thread a lil more action.
I can't do that. Perhaps a guide or mod will want to. I have no problem with it, I'm not even running it. Was so slow for me.
Id have to say this is the best "Sense" rom ive used so far. Thats saying alot cn as i dont like sense im a AOSP man, but i have to say im enjoying it very much and will use it prolly till i get bored and return to vanilla android. Its def a battery killa bur i have downloaded both Imos' and Ziggy's kernels and will play around to see which if either gives better battery life. Id def recommend ppl to try this baby out.
im likin at pretty well also. battery life is terrible,but i dont think its any worse for me than any other sense rom.
