Root Baseband DJ05
Toddw
I'm still trying to get a little better battery life out of my Fascinate. I have just noticed something about the installed software. First off I am rooted and running a voodoo kernel. I noticed that the Baseband version is a DL09 but all the ROMs I've tried are DJ05. The phone is working fine otherwise. Do these need to match? How can I get the Baseband version for DJ05?
They dont need to match DL09 and DJ05 are interchangeable radios. For battery life find the lowest uv you can run from imnuts menu. -100mv is a pretty nice increase over the stock
You didn't say which kernel you are running but you should try imnuts if your looking for battery life.
