Hello all,
I have very simple questions and I'd appreciate if someone could help me!
- Flashing a new ROM will overwrite service provider lock? If no, why? A lock is not part of the ROM image? It's stored somewhere else? What's the technical name of the area where the lock settings are stored?
- Related to the question above, flashing a ROM will automatically root the phone? Or the root information is stored outside the ROM?
- Why there are different ROMs for MetroPCS and T-Mobile versions? Aren't they the same hardware wise? If not, what's is the key difference(s) that requires different ROMs for each?
- I see some ROMs are based in the original (MetroPCS/Tmobile) ones. How were they able to get the original source code? Is it possible to extract the ROM from the phone (any Android phone actually) and modify the source code?
- Kinda related to the question above, to start a new ROM for a given phone, what's the start point: modifying it's original ROM or there is a basic ROM that would work for any phone (then you start modifying this basic ROM)?
Thank you!
Thank you!
