Gemini Yun
Hi Fellow Forumers,
I have 2 questions and hope that i could get a response to it
1) What is the good battery apps / widget that can show not only your battery power and usage graph, but also your battery MAH ?
2) What actually does battery calibration means and how do i achieve this. The steps to take to do this calibration thingy.
I just got my original Samsung S2 2000mAh with White cover.
Thanks all
Thanks all
unless u upgrade to the Pro Version which i did for awhile to check the real status of my new battery ..It does read as 2020mAh and i uninstall it to refund
in terms of batt its really worth investing in high quality ones...
