n7plus1
Member
So im experiencing a lot of the same issues most of you have. Had the problem with the phone making the charger plugged in, unplugged sound on its on. cleaned it. fixed it and then it came back. Downgraded to a previous firmware b/c i thought the recent LPW firmware caused the issues...this is not the case. I did the downgrade to LPS and did a reset and plugged the phone into the wall to charge and now it wont turn on at all. Battery reads 3.9V...nothing happens when i plug it in to the charger or my PC..any help?
Ive ordered a new battery (b/c it needs to be replaced anyway if i ever get this fixed) and a new USB connector/flex cable..shown here:
New Charging Charger Connector Port USB Flex Cable For Samsung Galaxy S 2 i9100 | eBay
if this isnt the issue, i dont know what is.
