silencertr3
yes it has gotten bad.. download screen filt so you can go below the factory back light..
Also, has anyone tried toggling "mobile data" on/off in an effort to conserve battery life?
I've got 3 main apps that I think are using mobile data frequently:
email -- set to push
Gmail -- set to push
fancy widget -- updates weather every so often
I'm assuming with "mobile data" off, these will NOT update until I turn it back on. That's OK for me cause I sit in front of a computer all day and if I want to check my email, I can do it on my computer.
Am I correct in assuming that mobile data kills EVERYTHING except phone calls/texts? Basically turns my smartphone back into a dumbphone?
Also, does anyone know what the difference is between this and toggling off the "sync" (circle-shaped arrows on widget)? I would think these were the same function. If I had to guess, I would say disabling sync ONLY disables email/gmail/maybe some app sync but leaves available other options (like web browsing).
Is this correct?
I don't know if this helps, but my Fascinate has been off charger for 4 days, 10 hrs, 46 mins, and I still have 50% on battery meter. Phone idle 19%, cell standby 38%, display 14%, voice calls 22%. Granted, I have a Samsung extended battery (and yes, my phone looks pregnant, but I choose performance over looks).
I did a factory reset after update to Froyo, not rooted, have 137 apps, use automatic combination of wifi and 3G, auto sync every 2 hrs (with Gmail, facebook, Accuweather, etc.), use a wall charger when I charge, average 6 texts/day and have about 10 widgets running on home screen.
I hope this info can help.
My phone can last anywhere from 4 to 12 hours depending on what I'm doing with it. I had bought an extra charger that comes with a battery with a Y split attachment that allows me to charge my phone and my extra battery at the same time (if need be). I usually charge the battery only and swap out so I'm always changing the battery once a day. I haven't had to keep my phone on the charger like I did in the past. I hope this will help a number of you out there so you can actually use your phone and not be stuck to a wall charging your phone constantly. I have enjoyed my phone since I bought this. Hope this helps.
Set Your Location
