Help Battery drain at night
fldude99
Android Expert
In the last few days my Captivate is draining battery when its idle. I'll go to bed..set it aside and in 7 hours its down 35%. I uninstalled a couple apps I thought may be a problem: Pageonce Travel and Lookout-but same thing. Only other thing installed recently is Beautiful Widgets but I'm not using it for wallpaper or the widgets. When waking in the morning I'll look at battery usage and I see that the display is the highest user-seems strange when the display is off all night...any ideas?
mine does the same thing - I think it's updating apps through the night. I've been meaning to place it in "airplane mode" overnight to see if that makes a difference.
When I had Missed Message Flasher or NoLED installed, they drained my battery. So if you installed anything similar, that could be the culprit.
Thanks..but nah thats not it. I'm just going to keep installing apps one by one I suppose. After all that I guess its a factory reset
Why dont you just plug it in at night?
