Hi all. I've had an issue with my battery draining quickly overnight a few times. I go to bed around 11:00 with the charge between 50-60% and wake up around 4:00 (thanks to the crying baby
) to the low battery indicator. One night that this happened I watched the battery drain 20% in about 15 minutes. While this happened I noticed the data indicator was going crazy although I wasn't running anything...just had the screen on to monitor it. In all instances when I check Spare Parts the only unusual thing I see is the dialer fills the bar in upload/download for network usage. Keep in mind that this happens while I'm sleeping with the phone near me and absolutely no use on my part. I'm rooted with Fresh 2.3.3 and I haven't installed any new apps installed prior to this issue. Any thoughts as to what could be causing this? Thanks for any suggestions!
tony
) to the low battery indicator. One night that this happened I watched the battery drain 20% in about 15 minutes. While this happened I noticed the data indicator was going crazy although I wasn't running anything...just had the screen on to monitor it. In all instances when I check Spare Parts the only unusual thing I see is the dialer fills the bar in upload/download for network usage. Keep in mind that this happens while I'm sleeping with the phone near me and absolutely no use on my part. I'm rooted with Fresh 2.3.3 and I haven't installed any new apps installed prior to this issue. Any thoughts as to what could be causing this? Thanks for any suggestions!tony
