mecampo
UID is basically the user id of a process. I'm not sure why spare parts is displaying that, specifically, but it could have to do with apps that use actual system functions. That's just a guess, but I don't see why else it would be displaying that rather than the actual app. In any case, there's no simple way of correlating those exact UIDs to the apps that ran under those UIDs. You can install Quick System Info from the market. Under the processes tab, you can see all of the running processes. Press on any process, and select details. You'll be able to see the User ID (UID) from there. I'd start by finding the processes for the things you know you used (facebook, poweramp, handcent, etc.) and seeing what their UIDs are. Perhaps you can make a correlation.
EDIT: 10019 is apparently gapps, or so says my phone.
EDIT2: That'd be the Google services framework, btw, in case you were wondering.
will install, thanks for the advise
