if you run the .591 crt mod on .595 you will downgrade your framework. its best to current mods and updates.
And I just read this too. It works but apparently its not the way you want to go. I havent seen a 595 version yet.
If you re-apply the .595 mods, you'll be on the current framework. Right now, you're on the .591 framework - unknown if there are any substantial differences.
Just sayin'.
Sweet! I should have been a bit more patient. If I had already applied the older version will applying this correct the framework issue with the older versions being laid down?
Looking everywhere for a multi color segmented circle battery mod for DX .595. Already running CRT but can't find the correct battery. Lots of smooth circles, and % battery cans but no segmented multi colored circles. Help? Thanx!!
Ytsud check out "uot kitchen" on the web. There you can make your own custom icons and if I remember right they have a multi color circle battery icon set.
