Root Battery issue. Says awake constantly. Need help.
Fuzzy13
Extreme Android User
My screen is off but it says its awake constantly. Didn't do this on B and i haven't installed any new apps since B.
Any clue why its doing this?
Googled and found people with the sane problem using an app called battery stats to find out what's causing it but it doesn't make any sense.
I've tried 2 different roms and kernels and it still does it.
I get readings like this when I'm using my phone as an mp3 player... I don't know if that helps.
try going to settings about phone development and see if u have stay awake checked
I didn't wanna wait hours to take a pic when it would have shown the same thing only longer. Lol
But, it wasn't search. I had forgot which ones i had already tried. Ive got it narrowed down to 5 apps/services.
I would recommend going back to stock then reflashing your favorite rom.if you have not already tried it. Usually fixes any bugs
Battery stats shows no deep sleep and fully awake until I freeze google framework. Then I get some deep sleep. Makes no sense
Okay so i jsut reinstalled the ROM. Stock everything is good. Im about to flash my theme over it and see what happens.
look in build.prop for user.feature.lgpoweroff=true
I have the issue and my build.prop was user.feature.lgpoweroff=false I change to true and all was fine
So everything was good until i uninstalled my usual last few apps that one might not uninstall. Then it started back again. So it looks like a system app that i delete is what causes it.
I can't remember them all but i know its dunserver, gmail, wapservice and a couple more. These are system apps I've always uninstalled with no problems and never this problem. Idk. Gonna try and narrow this shit down. aggravating
Okay this is what i uninstalled right before it happened again.
Dunserver
Downloads
Gmail
Lg keyboard
Oma dm
Power off
Search apps provider
talk
Vpn services
Wap services
And i freeze
Brcm bluetooth
Google calendar and contacts sync
akikhia said:
idk why but i feel it could b wap service i always thought it was fishy
I'm running down the list. I tried freezing all the culprits and it didn't show awake. Now i'm uninstalling one by one to see which one does it.
I've only had this problem on zvd. Makes no sense
I tried WAP and it didn't do anything. Im on the Dunserver right now. I've got 2 or 3 left to go. Ish just dont make sense. lol
Fuzzy, you've gone crazy.:dancing2:
Haha. I seriously have. I feel like one of those crazy people that sees things and tries to tell other people about it.
"See these aliens were standing in my kitchen making pancakes and they asked me to join, but I was running late for work so I couldn't stay. They were gone when I got home." :alberteinstein:
See this is how this ish should look. And i didn't diy anything different. Lol phone has a brain off its own.
