Ok, I remember doing this in the past. Remind me what this does? I assume the OTA undid what this did before?dial *22899 then see how your life is
Be sure you turn off application background data sync by going to menu, settings, accounts & sync and un checking
Background data sync.
Lol I legit laughed out loud.CArry a battery charger...............
found that the update is sucking battery power via my GPS. I used to leave my standalone GPS on all the time. Now I turn it off unless I am actively using it and my battery life is more appropriate. It is not a big thing b/c the lock on now is so fast for the GPS. I keep the Verizon and Google location on as well for those aps that need a general whereabouts to work (weather, gas buddy, etc)
Leaving the standalone GPS on all day has a minimal impact on my battery life, and it definitely helps the lock times when I need to use nav. Keeps it "awake" I guess. I still get a full day out of my Fascinate battery with GPS, bluetooth, and WiFi all enabled, all day long. This of course is pre-update. I think I'm going to give this update a try, though, and if it doesn't work well for me, after rooting and cleaning up a bit, of course, I'll just go back to a clean ROM or stupidfast kernel or something like that. Might even go back to one of dirrk's voodoo kernels.
