hi,
my phone just used 35% of its battery with one reset - it got stuck and I had to take out the battery to reboot.
this kind of stuff started to happen, after I swapped the ICS stock kernel with one to get root access. Now I'm not sure if its related to this or due to the apps I installed since.
Is there a way to somehow pinpoint the matter and thus, find a remedy?
Thanks for your help (not sure if that is the right forum).
