Tyler Perez
I just got the 4000 mah seidio battery with the convert case and I have to say so far I'm not impressed. I had the same setup with my evo 4g and that was great. the 4000 mah battery seems to only have about one and a half times increase in battery life over stock. This is surprising since it is rated at almost two 1/2 time's the capacity of the stock evo 3d battery. My evo 4g would easily double the usage of the stock battery. The convert case is disappointing as well, compared to the 4g case it is flimsy and the plastic skeleton doesn't fit snug with the silicone like the 4g case did. Hopefully the battery life will improve with time although the 4g's 3500 was great out of the box. One positive note> its the only extended battery/rugged case combination out there right now. Rick
I had the seidio evo 4g combo too, and i loved it... i didn't go seidio this time...
that's too bad it's not that great this time...
