scoope
I'm not sure, if you use Gmail though all of your contacts will be synced on your Gmail cloud. If no Gmail, check the Tmo server, it should also have your contacts there.
Where do I find the Tmo server?
I have exported my contacts to my SD card (00001.vcf file) I assume I will be able to import them back from the SD card after a reset.
Do I have to remove the SD card before executing a reset?
Also If you do not have to reinstall the update, does this mean that the reset uses OTA to get back to factory specs?
Thanks
Simon
