tom108
Android Expert
Thanks everyone, this seems to have fixed my problem.
glad to hear you got it worked out.
Edit:
I went to tether with my phone last night and discovered that I apperently no longer have root!. Root Explorer, SetCPU, ROMManager, etc wouldn't work.
Did I really lose root? How?
I was also being prompted to upload an update. I hadn't gotten the prompt before.
So this morning (Sat) I reinstalled Fabulous' ota fix and got root back. I don't know how I screwed that up the first time.
But I'm still getting the prompt to install the update. Is this because the update is actually already downloaded on my phone? Do I simply locate where the file is & delete it or accept the update?
As far as I can understand, Fabulous' OTA fix is supposed to trick the service provider into seeing your phone as having 2.1 installed, correct? (Sorry. I'm confused.)
...I expect this should be moved to the All Things Root section, but I didn't realize it was a root issue when I first asked about my battery problem.![]()
Psycho: Sounds like you've had a lot of trouble and you have tried piecing it together. If I was you, I'd use RSDLite to restore back stock 2.01. I'd then root it (do not accept the update). Then I'd install RomManager and download BBv1 and NexTheme. I've been running on it since it came out, without any problems - no battery drain, no prompting, no nothing. Maybe it's luck, maybe it's NexBeast!
Good luck!
H
I've been using Simply Stunning and Adams LV kernal. Battery life has been terrible recently so I tried otafix without reading the thread fully and unrooted my phone. Fortuneately I had a recent nandroid back up. I am going to try a data wipe and try BB 1.0 to see if it is any better.
