HereticSins
Android Expert
Is it bad to overcharge?
I do it all the time haha.
My first charge lasted 24 hours with normal use.
Yea my 1st charge lasted pretty damn long. Now not so much![]()
I'm at 15 and half hours with 22% left.
Yes I did exactly thatDid you let it fully drain?
And recharge fully while off?
That usually helps new batteries reach their full potential
i use the gps navigation alot and in
Sounds exactly like mine. I should be getting a new battery tomorrow I will update if anything changes.
Are your getting a new battery from MetroPCS? Did you have to buy it or are they giving it to you since you may have a defective battery?![]()
How do you tell which model you are?
So I looked at antutu for system info I guess I have the 1.5 to?
if you are using wifi does it count against your 2.5 gb data limit
i was watching the game on 4G and the temp got up to 113F and the battery went down 20% in the 30 minutes i watched.
