Help Battery or phone bad?
u7cappy
Mistakenly left Bluetooth and GPS on for a couple hours today which completely killed my battery for the first time. Had this phone since September of 2012. Every night since I bought the motion it has been plugged in overnight for 6-8 hours.
First problem I've had with my motion. Tried multiple chargers, trying a different battery tomorrow.
When I plug it in the bottom 3 lights just flash.
For the night, should I remove the battery for 8 hours, or leave it plugged in for 8 hours? Or is my phone / battery just fried?
I would say leave it plugged in for a little bit before trying to turn it on.
My old s2 and my s3 has this problem. If it dies on its own, it needs to charge a bit before it's able to power on.
While connected to my computer for charging, windows keeps detecting it, and a minute later it acts as though its unplugged. The phone is still off, not sure what windows is thinking.
Don't charge from the computer, charge from the wall with the charger that came with the phone...
Or, get one of the external stand alone chargers that just take the badry. Those eliminate any charging monitoring actions happening inside the phone.
I had one of those with a spare badry for my Droid Xs. Nice to have for when the factory chargers USB or charger itself goes TU and you want to shop for a good deal on a new one instead of paying xtree 'cause you Have to Have One Now.
Bruce in Ocala, FL
My battery used to be really good when I first got it... Now it is extremely bad ... always dying...I've bought some extra batteries from amazon ...but that isn't the point...I've tried various ROMs/setups/etc ... it always says that android os is taking the most battery:(
