Anybody experiencing this, my battery suddenly starts getting really hot after using tge phone for about 5 minutes ot sure if its a fault or not.
. but heat issue seems to be a hardware problem soooo....... sammy recall? lolI was going to start a new thread as I too am oncerned about the heat coming out of this phone. I'm not so sure the battery is where the heat is coming from. I think rather it's the top half of the phone. With the back off, the SIM card holder is probably the hottest. Not quite enough to burn but unpleasant and likely to damage the phone's components over time.
It's hard to compare temperatures without using thermometers but it's be good to get a fix on whether this is the same for everyone or perhaps a fault.
. the screen getting hot aswell is a worry to me... i think it might start to damage it... not sure.mine doesn't get hot. at all.
