Help battery percentage
webbs24
this may sound dumb but where can you see the battery percentage on the Fascinate?i cannot seem to find it anywhere
Thanks
Welcome to the forums!
Well, you have a few options. If you want to root your phone, I would suggest looking at this thread for a mod that changes the battery icon in your Notification bar. If you just want a homescreen widget or another icon in your Notification bar without rooting, there are a good number in the Market that essentially do the same thing. Try looking at the hits on AppBrain and choosing one you like.
Thanks
Very simple solution. I run this widget it works on LG Shine Plus, HTC Desire & Telus Fascinate. Simple readable numeric indication on the top level.
end of problem - see below for the Free version
Battery indicator Darshan Computing
I second the recommendation to Battstat, simple and light app that is quite accurate with the battery %
