Hi first post so I'm not entirely sure if this is in the correct section.
Right this may be a bit long winded so bear with me, last week my battery started playing up, for example the battery indicator will tell me I've got 86% remaining then 5 minutes later the its telling me to connect my charger then it cuts out, when I'm charging it will stay at 68% for a while then ping straight to 100%, at first I thought the battery indicator app that was just giving incorrect readings but I've removed the app and replaced it with another and its still happening, yesterday I charged it from 11am and took it out of charge at 13:45 and it was fully charged, at 14:50 it had cut out, I had only used my 3g 10 minutes. Pain the arse. Any ideas? App running in the back ground draining a full battery in an hour? Battery app not giving a correct reading? Or is the battery just f*cked?
I've checked its 'health' and it says it's good, I'm due an upgrade next month so don't really want to buy a new battery or send the phone back for repair, it's about 18 month old.
Cheers.
Cheers.
