trapperjohn
Hi,
I installed cm7 which really makes my phone fly compared to stock
I can only imagine how much faster it will be with other roms that are tweaked for speed!
But before I start changing roms I wanted to get clarification on how you would recommend handling battery stats file.
Should it be cleared and if so what is the best way to have it relearn the battery usage, I ask since I have seen conflicting ways on how to handle this.
Thanks,
Bryan
I can only imagine how much faster it will be with other roms that are tweaked for speed! But before I start changing roms I wanted to get clarification on how you would recommend handling battery stats file.
Thanks,
Bryan
